Higher limit speedometer gauge
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
Minnesota
Do they sell higher capacity dash gauges for my 92 ranger? As you may know, it maxes out at 85, and I want to have one that maxes out at 120 or higher.
Do they make them? And if they do, how do I calibrate the mechanical speedo to tell me my speed correctly?
Thank you!
make your own. just cut the bottem of the cluster and use a white marker/ paint pen and add your own speeds haha, because i think these speedos just keep spinning
The Canadian ones are marked in kph so they must go higher that 120 (I'll check on mine when I remember). then just change the gear in the t/case.
