ECLIPSED8001
- Oct 9, 2007
- Age
- 44
I Just Got A 1988 Ford Ranger Xlt 2.3 Liter 4 Banger. When I Got It, It Had A Bad Miss So I Replaced The Normal Stuff ....plugs, Wires, Cap, Rotor, Had The Ignition Module Bench Tested And It Was Ok. After All That It Still Had A Miss So I Asked Around And One Guy Told Me A Burnt Valve Was Possible. I Still Need To Do A Compression Test. Well I Just So Happened To Have A Brand New Msd 6al Ignition Box And A Brand New Blaster 2 Coil. So I Hooked That Up And Believe It Or Not It Actually Helped The Miss At Idle And Normal "through Town" Speeds. However, When I Take The Truck Out On The Interstate It Lacks Power.....granted Its Only A 4 Banger It Should Have A Little More Ass Than It Does, In My Opinion. Anyway When I Get It Up Around 60 Or Above. It Misses. If I Watch The Tach The Tach Actually Jumps From 2500 To 3000 Just For A Split Second And Its Intermitent. One Other Thing.....when I Had The Ignition Module Tested I Pulled The Distributor Completely Out To Get The Module Off. When I Put The Distributor Back In I Had A Hard Time Getting It In Correctly.......hahaha......knowing Better Than To Do This.....i Didnt Mark The Distributor Luckily I Have A Chiltons Manual. However When I Set The Time On It I Brought The Number One Cylinder Up To T.d.c. And Checked The Timing Mark On The Crank And It Was @ Zero. For Some Reason I Thought That I Had Read Somewhere That Factory Was Set To 10 Degrees Over 0 And Also I Thought That I Read That There Is Some Kind Of A Plug That I Need To Pull Off Of A Wiring Harness In Order To Set The Time Correctly. Any And All Help At This Point Will Be Appreciated. Thanks
Greg
Greg
