High Mileage Ranger Tranny issues
poconoracing
I have a 2003 Ranger Edge 4.0L 4x4 with 203k miles on it
Recently developed a 3-4 shift flare and intermittent flashing O/D light
Used ForScan and pulled 3 codes
P0733 - Transmission Gear #3 incorrect ratio
P0734 - Transmission Gear #4 incorrect ratio
P0741 - TCC system performance Torque converter slip detected
I have had the truck for about 12000 miles, prior history is unknown. When I got it I dropped the pan and changed the fluid/filter. Fluid was old, not burnt or gritty. No metal in the pan at that time, only sludge/wear particles from the clutches. Cleaned out the pan and new fluid. Ran/shifted fine until a few days ago. Otherwise the truck runs perfectly and seems to have been maintained. I bought it from the original owner.
I don't have a bunch of money to put a new tranny in it. Before I get too far I have a couple of questions.
Can incorrect band tension cause the above issues?
It seems these trannys have issues with the valve body gaskets. Is that a potential cause of the issues/codes?
I have reverse, and other than the flare that just developed there seems to be no change in the trannys behavior.
Its an old truck, swapping the trans will be a colossal PITA. My hope is I can fix the trans in the truck.
Been lurking on the forum for a long time, but this is my first post.
Any help is appreciated
Dave
Did all the codes appear together or has one been lurking? If they all came at once that to me sounds like a pressure loss in the valve body (gasket). Incorrect ratio is due the input/output shaft ratio being out of range. Bands/clutches are probably slipping due to inadequate pressure. Same with the Tcc slip code. The tcc solenoid is modulated with a pulse signal. It slowly increases the pulse to 100% duty cycle so the TC is less of a jerk. If the slip is too high it will throw this code.
Thank you for the quick reply!
That's a really good question, I didn't clear them and drive it so I don't know if they were set together, or ones been lurking a while. It's the first time I scanned the truck. I'll clear them tomorrow and take it for a spin and see what codes reset.
To get that TCC one to come back you will have to be cruising at highway speed. Set up forscan to show actual gear ratio, commanded gear ratio, gear commanded, Tcc duty cycle, Tcc slip ratio
Ok. I'm new to forscan. It's quite the piece of software! It'll come in handy with my diesel excursion as well.
You are talking about setting up the PID dashboard with those values and driving it, correct?
Yeah that's correct. I like doing the table setup instead of dashboard. Which adapter are you using? Obdlink mx or generic elm327?
Ok. Only drawback to the generic elm327s is a slow refresh rate. If you load too many pids to read it will take longer for each one to refresh. If you are only looking at a handful it's fine but if you load up a full page full you will see the increase In refresh rate.
Makes sense. For $30 I shouldn't expect too much. I'll clear the DTC's, load up those parameters and take it for a highway run and see what I get. Hopefully I can get off of work tomorrow early enough to do it.
Thanks for your help so far. I appreciate it.
Ok I ran It with the codes cleared and the data stream being logged. It really had issues until it warmed up.
Any help you can give me would be appreciated. If you neeed the picture of the graphical data, let me know. its too big for the forum
Welp - I guess we know whats wrong....
Ran it to get the codes to reset today. Got 2
p0733 and p0741
After about 10 minutes of driving the trans temp spiked on forscan, lost all movement and tranny fluid came pouring out if the bellhousing.....
I'm guessing the TC gave up the ghost? or the pump perhaps?
It's going to have to come out.
Any leads on a used tranny in NE PA?
