purplepeopleeater
- Sep 11, 2010
Just a quick question hopefullly.
I took time 87 ranger 2.9 to emissions yesterday, did great on everything but the hydrocarbons at idle. 220 ppm to pass, I went through at 1427.
Have brand new plugs all gapped correctly, brand new coil
Brand new distributor,cap,and rotor. Set at 10 BTDC
Brand new IAC
Brand new MAP
And brand new PCV valve and grommet
I will replace plug wires and confirm no vacuum leaks. My question is, if I were to retard the timing to 8 deg BTDC, will that help to lower the HC at idle? Then once I pass I will re muteness to 10 BTDC
Thank you for any help.
Brand new IAC
Brand new MAP
