hiem?
check out ruff stuff...they have a killer deal on a set of 1 1/4 heims... plus they are a vender here
not looking to spend over 80$ soo ruff stuss is kinda out and rod end suplys website is down
you dont want to use a heim joint, use a johnny joint, they are designed with teflon arround the ball, and are made to absorb a shock... I got mine from currie enterprises. (watch the vid on there sight, it will explain why its better to use) i believe i used the 2.5'' with the 1'' shank
Try again....
Currie Enterprises said:
The bushing in the Johnny Joint® rod ends are made with a high density, "tough 88" urethane that encases the inner ball. Its a very durable material and it is impervious to weather...Currie Enterprises-LINK
Typically, most large rod ends have Teflon or Kevlar race inserts (if specified), while most (if not all) flex joints use some type of polyurethane-based bushings.
personally i think i would run the ballistic joint over the orig johnny joint [aka jhon currie] its bigger and it seems to have a warranty and it has an option to have a solid race witch im not to clear on right now
