hiden start buton in my shift nob
meanasposible
ok so i just bought one of these and im wondering if i could get some help with these confuseing derections ( im more familar with engins than stupid little wires)
i have a 3rd gen 4L 4x4 ranger
ok so it says atatch one wire to terminal 15 behined the ignition switch and atactch the other green wire to terminal 50 witch is aparently also behind the ignition switch
then atatch the red wire to terminal 15(power that passes through the ignition)
im sory that i cant spell but thanks for the help guys
get a test light with a sharp needle tip, attach the alligator clip to a good ground, poke the large wires going into the ignition switch to find the wire that has 12v with the key off. use a quick splice to attach one of your starter button wires to this wire.
then poke around to find the wire that has power ONLY when starting, it should go on when cranking and go off when you release the key. attach your other wire here
