Hey guys is there a way to eliminate the A/C but keep the heater??
4byRANGER
i dont want the bulky a/c under the hood anymore(dosent work in the first place)
but i like having heat during the winter cause i snowboard alot.
what options do i have?
you can remove the heater ac box heater box and replace it with a non ac box and then remove the rest of your ac components. i did the same thing on my 94 because i wanted maximum room in my engine bay for my dual batteries and maybe onboard air down the road so i ditched it all. im still running the ac heater control panel with the push knob because i plan on using the push knob switch to turn on my air compressor when i do an OBA set up, but i also have a non ac unit to install if i decide to go a different route.
