CarsonChris
- Apr 1, 2011
I just got back home and started digging into the BII I bought last weekend. I knew it had bad valve cover gaskets.
Thermostat, bet it hasn't been changed in ten years.
Oil, black as the darkest night. Don't see any radiator mix in it.
radiator fluid, a little dirty.
Question on valve covers? Will a leaking valve cover also create moisture buildup on the inside of it? I've got lots of moisture up top. The radiator didn't drain any when I've fired it up so I'm not sure if there's a cracked head or blown head gasket. The top radiator hose had a lot of pressure buildup when it was warm.
Will dig a little deeper later today.
