99RangerBoss
hey if you just installed a new slave cylinder or what have you might i suggest buying a hand vacuum tool that also does hydraulic brake lines i used one the other weekend when i put in a new slave cylinder and what a difference it worked amazing all we did is crack the bleeder screw and pump the shit out of the clutch and the vacuum tools and in five minutes all complete although it did take two of us it went great, also really weird when i disconnected the slave from the lines i pushed in the white collar and pop came loose no problems at all the job went super well for a newb and not even the exhaust gave use problems even after 6 years worth of winters under her belt!
hope this helps guys that little $20.00 CND tool works great! it comes with a no B.S. guarantee
