Here are oil pump seal and gasket P/Ns
ben_2_go
Third rock from sun
2.5 (4 Cylinder)
235-75-R15
None at all.
While disassembling my 2.5L, for what I thought was a broken timing belt,I found the belt had jump timing due to a massive oil leak.Thank fully the timing jumped enough to stall the engine before it lost all oil pressure.I knew I had a pretty bad oil leak and suspected the front crankshaft seal.It's usually the culprit.During tear down,I rotated the oil pump when I pulled the timing belt up out of the plastic housing, and oil ran out from around the bottom of the pump housing.So I went on a two day search for part numbers and finally found them.Here they are.
Inner O ring 87071-s100
Outter O ring 87072-s100
Gasket F57Z-6659-A
I could find the gasket but I couldn't find the two pump O rings any where.
