russ09
- Aug 22, 2010
- Automatic
I have a 92 2wd ranger with a 3.0 and auto tranny. It recently quit on me so i narrowed it down to a fuel problem so i replaced the fuel filter and the solenoid switch which has be faulty at times requiring me to jump it over to start the truck from time to time. when i did and turned the switch nothing happened. Then i tracked it down again and replaced the starter. Now only when i jump over the solenoid will it turn over but not run and the switch is on when i do this all the fuses in the box beside the solenoid switch are fine. What could it be the ignition switch on the steering column or another fuse under the dash????
