Rusty Shackleford Gribble
Hi all and thank you in advance for any advice!! So I have a 91 ranger 2.9. I was driving one day and it started running really rough. I made it home and then it wouldn’t start. It took me FOREVER to figure out that it was the ecu that went bad. Bought one from rock auto and fired right up. A couple weeks later it died again. Same exact symptoms. The ecu was under warranty so I ordered a replacement. Fired right up again. Well…it just died again. Same symptoms. I’m pretty sure I know what the culprit is. My question is, are any of you aware if there’s something else faulty the system that could be frying these units? Or is it possible these remans are just garbage? Oh, and when I swapped it the first time, the ecu that was in the truck when I bought it was a reman from 2015 so someone had already replaced it before. Thanks!
