Stangman Don
- Feb 24, 2011
- 1996 ford explo
- Automatic
my 96 explorer 4.0L has had an intermiten issue that seems worse when the temp is milder or the truck is hot. It starts just runs rough bogs,backfires etc never smokes though. Sometimes it stalls and wont restart(if you walk away and leave it for 30min it will start up and run perfect). Sometimes when it wont start the power locks will keep locking and unlocking when you are trying to start it. I have done fuel pressure tests,vacuum tests,spark tests all came out good and put close to $600 in sensors tps,crank,o2,map,idle control,maf,coolant temp sensor,egr,mudule,wires,plugs, etc! I have cleaned every + & - contact on the truck as well and checked all relay/fuses/wires for corosion found nothing.
When it is running it runs perfect no issues. When it acts up once you get it running and go 2 truck lenghts it smooths right out and runs great till you shut it off for anywhere from 10min -45min if it sits longer than that it does not act up!
