Help with wiring please!
shadowfox
Central PA
I had heard wiring was easy, just match up the colors. Well there's a slight problem, only like 2 wires match up. Plus there are 2 thick wires on the new harness that came with my radio and only 1 thick wire on my old radio harness. I read the wiring diagram and found all the wires. I need some serious help please. Here is a list of all the wires on the new harness.
Black (thick)
Yellow (thick)
Red
Blue
Grey
Grey with Black stripe
White
White with Black stripe
Green
Green with Black stripe
This is confusing me and I know not all the wires will be used. Any help would be greatly appreciated!
Does your harness still have the plug on it that goes into the stock stereo? If it does then you can make short work of the job by buying the adapter harness that most walmarts, meijers, and best buyscarry. If the stock plug is missing then refer to the wiring diagrams in the tech library.
http://www.therangerstation.com/tech_library/radio_wiring_diagrams.html
whered you buy your radio crap from? crutchfield gives specific install hardware so you dont run into as many problems...
I got my radio from walmart because it was cheaper there than bestbuy and crutchfield. and i bought a harness so i got it hooked up
Find a wiring diagram for your model harness from the manufacturer usually it comes with documentation, and the wires usually are labeled on the back or bottom of aftermarket decks. I know I've had to physically check all the speakers by hooking one up with the deck out and powered while adjusting the balance and fade to only one speaker at a time then labeling those suckers forr future referance. Then use a test probe to find constant and swiitched power. Ground is always black, the illumination and other stuff can be tougher but trial and Error with some patience will get you there if all else fails. But definately a diagram for your model is a huge help. Ps sometimes the harness wires are labeled for their function.
your a ****in idiot never touch anything to do with wiring ever again. thick wire wtf?
http://www.the12volt.com/installbay/stereodetail/880.html
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Chassis
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Rear Speakers 5" x 7" Rear Wall
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Negative repped. Usually on the head unit harness, the yellow wire is thicker than the other wires. Now you look like the idiot. :haha:
