Shran
Junk Collector
Solid Axle Swap
Truck of Month
A couple suggestions:
HF wire feed welders are trash. And they're AC only. Flux core wire is also one of my least favorite things - I have run a LOT of it over the years, think of it like an endless stick electrode...because that's essentially what it is, it requires even more cleanup than stick welding does.
A good "cheap" MIG welder could be a Lincoln, Miller, Hobart, HTP, or Clarke. I have had several Clarkes and was very happy with them, much more so than the HF crap. No longer made but they were fairly well made and HTP sells parts for them.
I currently have a Miller 211 that I picked up like new from a pawn shop for $400. Can't imagine going back to a cheap machine, the quality of my work is just so much better.
Ideally if you can find something used that will allow you to run gas at some point and run on either 110 or 220, that would be ideal... I know what narrows down the options a lot, but seriously, do you want a $100 tool that will frustrate you from day one, or a slightly more expensive tool that does exactly what you want?
Speaking from many years experience and semi-professional welding jobs I have done.
