Help with Turn sig
dman
I have an 03 Edge and my front passenger turn sig died on me this week and I'm have a difficult time figuring out how to change it any help would be appreciated
Check this video out: http://www.youtube.com/watch?v=hn92huxwVkM&feature=channel
Of course, you only need to follow this part way... just to the part where you need to remove the turn signal bulb, you DO NOT need to proceed any further than that.
The two tabs may need to be moved up and down a little bit just to get the light unit out... be sure to take your time to get everything aligned when you put the headlight back in.
Hope this helped!
thank you you i also want to thank ford for not putting the first step of the process in the owners manual
Not a problem, that person on you tube tends to have some very helpful videos.
