Help with transmission issue
TCossuto
Okay, I've got a 95 ford with a 4banger in it. The transmission is completely electronically controlled, so I'm kind of at a loss.
There are a few issues with it. The "OD OFF" light will sometimes come on and flash. Also the transmission shifts hard most of the time. I replaced the fluid and filter, but same issue. A little better with LUCAS transmission tune, but not much.
Can anyone throw me some ideas? There's obviously no vacuums to check or linkage to adjust. It's all electronic.
You have to get the codes pulled from the PCM. Can't really help untill then.
