Help with sway bar links.
jarfly
Welp something eles broke, I swear I think 4 wheeling cost more than hookers and blow. lol But any how. My frount link broke on my truck, I really don't know why a plastic link came with a lift.
Got to thinking could I use links from tractor supply? it's fpr a 6" lift.
Thanks
I always make my own, it's not hard. You should disconnect them when going off road anyway, better articulation. To answer your question, I've not seen the ones from tractor supply but if they fit I don't see why not.
if you are running a TTB set up.....and Ranger lift coils.....do like the majority of folks on here and ditch the sway bar all together....
I DD my lifted truck for almost 3+ years with no sway bar and could barely notice a difference....
l8r, John
l8r, John
what he said... I haven't ran a sway bar since about a year after I converted to 4x4 (say about 5 years), currently DDing my truck 80 miles a day and it drives fine...
i'm gonna make some jeep tj JKS quick disco's work on mine, since they are threaded so far down... they are so adjustable.
JKS
one of the rough country ones are like that to. the ones that use a piece of tube between the 2 ends... take the pins out and then remove the tube.
the RC ones i'm speaking of
plan was to replace the center tube w/ whatever length I needed..
im just going to try to make some than, i hacked to geather one last night to get me by for a wile. Pretty well just stocker cut and extended. The bushings ain't in the best shap so I guess i'm goin try and find some heims that size and make removeable ones.
have you driven without them? I didn't even notice the difference stock height with 31's... put like 500 miles on the Ranger with 35's on it without sway bars in the last 5 days, half of that on the sand dunes and it felt fine...
