help with rear lift.
jarfly
Okey on my 97 I'v been workin on has egh......stacked blocks, stockers with a 3" Sure it works but I hate hacked stuff and stack blocks is on the top of the hack lifts imo..So im thinkin i got 4-6" So whats the best and cheapest way to get this with out useing stacked blocks? I really dont want to give 300^ for lift springs. So i was thinkin the chev leafs?
Chevy leaves, maybe with belltech shackles.
Almost wish I had 97 for more lift options but I like ifs...
chevy leafs, lifts about 2", but good and flexy, then some longer shackles, and maybe a 2" block if needed.. idk exactly the amount of lift you'd get tho.
if you can find explorer leafs at a jy or craigslist for cheap you can use those. I think they give 2" of lift and use a belltech 6400 shackle that'd be 4" and if you want more you can mix your ranger leafs with the explorer leafs, like have the top leaf explorer then ranger then explorer and so on. You may even be able to get 4" out of just doing that.
the exploder leaves lift each vehicle differently. depends on how saggy your current suspension is and how worn out the sploder leaves are.
you could go with the factory 2" block and the extended shackles and then get an AAL if you need more height
goin try the chevy leaves and might try to make a set of shackles not sure yet gotta look at some prices. but i just want to get away from the stacked blocks for some reson they scare the shit outa me. lol
