nooch450
I have a 1991 Ranger XLT Supercab 4x4 4.0 OHV 5 Speed Manual.
I am planing on buying a class 2 6" skyjacker lift with everything exept shocks.
I was looking at the Bilstein 5100 Series and 7100 Series shocks.
I want to run this truck at pretty fast paces on wide trails with rocks ect.
I Can find 5100 series shocks designed for my ranger with the 6 inch lift,
but i would like to invest in slightly better shocks like the 7100 series,
has anybody had experience with these.
i would really rather use these, but i must order specific shock rates, are they worth it over the 5100 series? will they bolt up or require fabrication?
I want to also run 35" tires. 12.5-13.5 wide if i can... ill cut the wheel wells if nessasary, i want to maxamise travel so 33" may need to be used. advice?
how much of an offset rims should i go with for the wide tires? also can anybody point me to some wide rims with offests without paying an arm and a leg?
what kind of wheel travel am i going to get out of the skyjacker lift?
Please let me know if you have any information on the above topics you can share with me.
Thanks Guys
Thanks Guys
