I would measure the coils…17” or so= 4” coils…19” or so= 6” coils. If your coils are shorter than those then you should look into new ones, if you already have 4 or 6” coils then adjust the camber/caster bushing until the wheels are as straight as possible and adjust the toe, then take to get aligned. You may need to pick up a set of 0-4* adjustable bushings to get it back into spec. I end up just doing the alignment on my truck myself, its not that hard to get it within reason
just my 2cents
just my 2cents
