Help with grinding/popping after lift
afdoc
Hoping someone out there can help me with an issue. I have a 2008 2WD Ranger which I lifted with Camburg's 5.5 lift about 4 months ago. I've put about 1600 miles on it since the lift, primarily on the road with occassional mild bumby dirt road riding. I haven't taken it off-road at all primarily out of fear that the thing will spontaneously fall apart. I have noticed a grinding sound/sensation coming up through the floorboard that has worsened with time. In addition, there is a popping/clunking sound/sensation with even the most mild bumps in the road. This all seems very noticable at slow speeds, primarily between 0 and 15 MPH. As I speed up above 15 MPH I really don't notice it. Also, it happens regardless of whether I'm steering right, left, or straight. It also occurs regardless of whether I'm in gear, in neutral, braking, or not braking. It basically happens ALL the time. It is a rythmic sound/sensation that increases in frequency as the truck goes faster but diminishes above 10 MPH and seems to disappear at around 15 MPH. It seems to be rotational, but not entirely sure. Also, when the truck is parked I can push on the outside of the drivers side tire repeatedly, setting the truck to rocking gently side to side, and there is a noticable cluck somewhere in the suspension. I have to rock the tire pretty hard to get this to happen, but it's there. It seems more distinct on the drivers side, but I can also feel it somewhat when I do the same to the passenger side. I've had it in the shop twice now with every bolt re-torqued, adjustable camber bolts installed, 2 alignments, wheel bearings inspected, hub assemblies re-torqued, etc... Basically, they have looked at the entire suspension twice since the install without a clue as to where the sound/sensation is eminating. It gets a little worse everyday and I'm getting afraid to drive the truck altogether. I am at my wits end and wishing I'd never done this to my new truck. Any clues? Any issues with the spindle shaft coming loose from the spindles after being pressed in? Any issues with brakes/calipers, etc..? Any issues with the uniball? I'm simply looking for anyone who might have some out of the box thoughts on where I should go from here. I have seriously thought about just pulling the kit off and going back to stock. Thanks for any insight you might offer.
if you can post up pics of the suspension and possibly a video of you rocking the truck and the camera lookin at the suspension from the front i might be able to help pin point it for you. as for the grinding, that kinda sounds like the backing plate for the rotor is hittin the rotor, assuming the wheel bearings are good like you stated
Have you pulled the whole wheel bearing and brakes apart. you might check your brake pads and make sure they are wearing even. very slight but maybe you have a brake pad draging causing the grinding sound up to 10mph. you might also check to make sure your rotors are not warped causing a odd wear issue.
ID'd the uniball on the drivers side as bad. Replaced and all is well with the world. After the headache of trying to figure it out, I was surprised it was an essentially new uniball. Lesson learned, take nothing for granted, even "new" parts can be defective.
So did the UNI-ball have slop in it or was there jsut no teflon in it? if it had slop in it, the shop should have noticed that first thing. I always chevk ball-joints/uni-balls for that stuff even if its new. Its surprising how many new parts are bad before you even put them on. I never asked that in my post cause you were sayin how they throughly checked over it so many times. oh well, glad you got her fixed!
