transmissions
So, I'm buying a 95' 4x4 ranger splash for 500 bucks tomorrow, it's in decent condition, the motor ran according to my mechanic friend a month ago, but the truck has been sitting for 3 years and is going to need a lot of work as far as fluid systems and suspension parts.
I'm going to be replacing the fuel lines, brake lines, and springs, wheel bearings, brakes, rotors, calipers, and pads.
First off, how do I flush the fuel, brake, and oil systems?
I know I can drain the coolant and oil from the block, and as long as there is no sludge in the oil, I think that'll be fine.
But how do I clean out the gas lines and everything?
I'm gonna drain the gas tank out, but is there a plug to drain it out from the bottom, or do I have to pump it out?
How do I clean the fuel pump?
How do I clean out the fuel and brake lines?
Should I wait to see if there's gunk and particles inside, and then flush it?
Or should I just flush it out with some type of solvent and drain it?
What type of solvent should I use to flush everything out with?
What are some cheap and decent parts to use for brake lines, rotors, calipers, brake pads, wheel bearings, and anything else you guys think I'd need to replace.
Links would be awesome.
Is the 8.8 explorer axle with disc brakes worth the swap?
