mccoady
First let me say I'm not mechanically inclined like most of you here so take that into consideration when I ask what might sound like dumb questions.
I have a check engine light that goes on and off randomly so before I took it to a mechanic I wanted to know how much it might cost. I bought a Autel MaxiScan MS409 OBD II/EOBD SCANNER- http://www.auteltech.com/ms409.htm & manual- http://www.auteltech.com/manual.htm
After running the scanner I get two codes:
P0300 ($10 Generic) Random/Multiple Cylinder Misfire Detected
P0303 ($10 Generic) Cylinder 3 Misfire Detected
Now the Autel MS409 has a DTC Lookup so when using it I get P0001 > Fuel Volume Regulator Control Circuit/Open
So my questions:
1. First what do the codes mean and what are my issues?
2. I've never used a code scanner before so why after I use the DTC Lookup do I get a different code (P0001) from the first two (P0300,P0303)? If someone was trying to help me and asked for the codes which would I give them?
So my questions:
