Help Truck Is Moving With Clutch Pushed In ..
scottc971
Williamston S.C.
:nono: IVE BEEN BLEEDING THIS CLUTCH FOR A WEEK NOW I THINK ITS MORE THAN AIR.TODAY I DONE IT AGAIN AND DROVE STILL HAVE TO PUMP IT TO SHIFT WHILE DRIVING.THEN GET HOME AND NOW ITS PULLING WHILE THE CLUTCH IS IN ,AND YOU CANT TAKE IT OUT OF GEAR UNLESS YOU CUT THE TRUCK OFF .THIS IS A 93 RANGER 4X4 ANY INFO WOULD BE THANKFUL...SCOTT
When you bleed it, does air come out every time? If so, you sucking air in somewhere, and is it leaking fluid anywhere, out of the bellhousing?
If It Was Leaking Wouldnt The Resovoir Be Low After A Few Hours. I See No Sign Of Leaking.when I Crack Bleeder It Dribbles A Little Fluid And Then Stops.but If Open And Clutch Ressed Fluid Shoots A Fast Stream .i Guess Im Bleeding It Right Anyone Got Ifo On Bleeding Clutch Ive Read So Manyways Online I Dont Know If Im Doing It Right Or Not Thanks
You aren't bleeding it correctly if the master cylinder is still attached to the truck.
I have NEVER sucessfully bled a 1993 master cylinder after it was installed.
AD
