- Jul 31, 2021
- NW Florida
- 2.3 (4 Cylinder)
- Total Drop
- 1.5” till I get these springs replaced
- Tire Size
- 225-70-R14
Ok so I know basically how axles and diffs work, but I don’t know what’s serviceable or how they’re put together. My goal is to raise my current ratio.
Differential: pop off the diff cover and what can I do? Are there bearings in there that should be inspected? Change ratio by changing a couple gears? Change the diff?
Wheel bearings: changed from the end? Pull out one side’s shaft and one bearing is on the end (near the differential when reinstalled) and one is is out by the brake? Are they packed or lubed by diff oil?
Just looking at the rear axle under the truck: there is the big diff ball in the middle, one shaft going to the wheels on either end, and drum brake stuff on the end. Are the shafty things bolted to the diffy thing or is it all one piece? Drum brake mounting plate thing replaceable?
