EnglishDan
Has anybody come across this...
My 1994 3.0l 4x4 started and ran great until a few days ago!!
Now, when I try to start, sometimes it fires up straight away but sometimes it doesn't fire. The engine is turning over fast as normal but it will not fire. I will turn it off and try again - exactly the same. Then maybe on the 3rd/4th/5th try it will fire up right away. It always starts eventually?
It doesn't matter how long I hold the key, if it isn't going to start that go - it isn't going to start! When it does want to work it fires as soon as the key is turned (as normal).
The battery/alternator/spark plugs/leads are all fine
I also had the fuel system and injectors cleaned out today - the mechanic couldn't find anything wrong, it started first go every time for him!!
Once started the truck runs and drives great - no problems with fuel starvation!
Any suggestions?? - HELP!
