whynotthinkwhynot
- Oct 11, 2007
- Age
- 54
- Automatic
I have 92 Aerostar that I use for my business. We haul ladders and some material, so you can expect about 600 lbs on the van at any given time minus passengers.
The old flat tappet 3.0 gave out on me the other day, and needs a rebuild. I have a roller cam engine from a Taurus which I believe was an FFV vehicle. From what I understand I can transfer parts from my engine to this one to make it work in RWD. I plan on a full rebuild, so the head gasket difference is not a problem.
The main problem with this van is that it lacks power. It always has even when it was running right. I'd like a 4.0, but finding an Aerostar wiring harness for that engine is a problem. If I can do it, that would be the best way to solve the power problem IMO. Yeah, I know I'd need a transmission, mount, and crossmember as well.
Ok, so if I'm stuck with the 3.0, what would be some recommendations? The ECU is a MAP sensor not MAF- which is good in some ways. Some of the things I don't know that I'd need to know:
1) Do Rangers have a driver's side exhaust manifold with the oil dipstick going up through the manifold between the runners on 4 & 5? I'm trying to figure out if I can use shorty headers.
2) StuffforyourRanger mentions that the roller rockers require tapping the head for studs. I assume this is to convert to SAE so you can use locking nuts for adjustable rockers- is this correct?
3) My 97 Aerostar 4.0 has a DIS run off some device that fits where the distributor fit. Did later model 3.0's have this same setup, and can it be made to work in an earlier engine/ECU with some rewiring?
4) What's the largest TB I can fit on a later model intake manifold, and what year model should I be looking for?
Thanks, I'm still not sure what's going to happen to the van. A motor is cheaper than a new van, but then I'm still in an old van. Sadly, rebuilding the flat tappet block is likely not going to be an option. I'm fairly certain the rings have been ripped off, and it would be cheaper to use the roller cam block than rework the old one. I'll know more when I get it out. To make matters worse- I don't have a lift. Aerostars are no fun to replace engines without a lift.
Thanks again for any help!!
