Help on D60 swap
1985Ranger124
Penngrove, California
I would like to do a sas on my 85 Ford Ranger, but i do not know what will work. The width can be about 8 inches over stock. I want really just a list of vehicles that I can pull the front end out of and have the least amount of work to get it in. Also I will be running leaf springs. Anything helps thanks.
Look in the Extreme suspension section, you'll find your answers there. As for where to find the axle, try Craigslist or if you have an auto dismantler near you first, see if you can't find a drivers drop D60. If not, you'd need to look for '70s-'80s maybe '90s F-350 or F-450, or 1 ton Dodge. A Dana 60 is a Dana 60, so long as the diff is on the drivers side it'll work.
-Jester
