95MEXIFORD
- Feb 23, 2010
The truck in question here is a 94 2.3 5 speed(of course). When I bought the truck 4yrs ago, I had to replace the transmission. So I went ahead and change the clutch,pressure plate,flywheel slave cylinder and pilot bearing. After about a 6. the throwout bearing started whining and about the 8mth Mark it exploded!. We checked to see if maybe the clutch fingers were bent but they weren't. So after about a year, same problem. Started whining and let go. I keep it well maintained and I don't drive the truck hard. Don't ride the clutch and I don't down-shift the tranny. Any of you fellas having this same problem? Or can you give me some advice?
