HELP! Oil leak!
shyster666
Hello,
been awhile since I posted, but I have a 2002 ford ranger 2.3L
Last night I noticed an oil leak and traced back to the water pump?? I started the truck and looked to see if the puley was slinging it, but when i was wathing you can see it coming out from behind the water pump pulley? There is no water in the oil that i can see. Any input would be appreciated.
most likely a cam seal or valve cover gasket.
