Servekaos
Hey guys, I've been having a serious issue for a while and I need to find a way to remedy it in the next two days to renew my CT registration.
I initially failed my emissions tests for a misfire code that was addressed. Basically, my O2 sensors were lazy and it was causing an intermittent misfire. This was causing the O2 sensor and a few other sensors to set as "inc" during the drive cycle tests.
The repairs have been completed to the satisfaction of OBDII going as far as to set all but one of the monitors (catalyst monitor) to "OK." I've done the complete Ford driving cycle several times and each time the result is the same. Each monitor will set within about 10 minutes of driving, except the catalyst monitor.
The problem is that, though OBDII recognizes the monitors have been set, each time the truck is shut off for any period of time the readiness monitors are cleared out again. Thus, I have tried to pass the emissions test something like nine times, each time the result being an aborted test due to the readiness monitors. It's very, very frustrating because I know I should be able to pass but now there's this.
I've heard that weak batteries can cause this issue but the battery is new as of last season. No corrosion on the terminals or cables that I can see. Also, my clock on my radio doesn't lose time or any of my settings so I don't think voltage is dropping too low. Also I've been told to check my fuses but none of them seem to be bad. I don't have any aftermarket alarms installed but there is some type of towing accessory that I've never used that isn't from the factory. The wiring for that sits directly below the steering column so I was able to eyeball it and it doesn't look faulty at all. This was installed when I bought the truck and did not cause it to fail emissions last time.
In case it's helpful, here's a short list of major parts I've replaced in the past year: 6x spark plugs, 6x wires, fuel filter, coil pack, FelPro upper intake manifold gaskets, new OEM O2 sensors (all three), new battery, new thermostat, misc. other parts.
tl;dr: The drive cycle monitors on my truck keep resetting every time the truck is shut off for no apparent reason...gotta pass emissions tomorrow! HELP!! lol
