Help needed
chill199124
West Virginia
Hello names Charlie I don't know if this is the proper place to post this if not please correct me but my 1999 ford ranger 3.0 5 speed 4x4 is having a 4wd issue were the t case really in the dash when I turn the key to on it'll click a few times stop click some more then the lights will flash for 4h 4l I recently replaced the t case motor and all 4x4 fuses and relays any help would be well appreciated or if yall know somewere that makes manual tcase conversion for less then a arm and leg
Hey Charlie,
Welcome to TRS...
This area will work...if not one of the Forum Staffers will move it for you.
So what is the problem?
Does 4x4 engage or is it just the dash lights are flashing?
Let us know.
I moved this over to the transfer case forum.
Look in the Tech Library... there are diagnostic procedures there for the systen.
I had a 97 expedition do this when the dash switch went bad
Welcome to the site.
See I replaced just about everything the switch the motor the t case relay all fuses sometimes it'll kick into 4h then when I try to go to 4l or 2wd it starts clicking then goes to 2h and lights flash I want to go manual bit it's alot to get
Hey Charlie,
Welcome to TRS...
Let us know.
So it engages but immediately kicks out sometimes it'll stay in 4h but will not go into 4l I'm wondering if I didn't install the motor right
Which switch was it if you can remember I'm thinking it's a combination of cold weather trash exhaust and residual antifreeze in the exhaust well I'm praying that's what it is I'm going to change the plugs and see if that helps with the slight miss
