modelageek
- Jan 31, 2009
- Boston, MA
- 4.0 V6
- Automatic
my brake line rusted out right at the drivers side rear wheel.....I pulled all of the brake line from the connection at the fuel filter back. I am going to replace the wheels cylinders and every thing else from the connection at the fuel filter back. I went to Autozone and they were useless as usual. the bracket that holds the brake-line to the rubber hose( right rear wheel area) was rusted and while removing it I had to cut the rubber stop off. I think this is called a suspension stop but I could not find it on rockauto. I also need the 4" metal bracket that gets held on by the stop and connects the line to the rubber hose......it looks like the flare on the line that connects at the fuel filter is a Bubble flare and the other end is a double flare. is there a union fitting that I can screw into that fitting to convert it to a double flair so I can use lines with fittings on them? has anyone bought prebent lines before..........any and all help would be great!!!!
