Help me with this wire
disciplerocks
July 2011 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
Evansville, IN
Where does this go to? It goes down under the compressor and then its ripped out of where ever it came from and I can't find it.
you need a brighter pic, I have no clue what you are meaning...
if it's just a single wire it probably is for the oil pressure sender.
It is tough to see, but I was thinking it was his temp sensor. The valve cover I think gave it away for me, plus the lower intake shape and there appears to be the coolant neck. I have a mainharness I could see where the wire runs, but it's from an '88 and looks like it's totally different.
Edit: I know what you meant now holyford lol, I was confused on what he was actually asking.
As far as fixing it where it's ripped out, what exactly do you mean? If a portion of the wire pulled out, you will either have to tear down the harness, solder it the wire back together and re-assemble, or run a new wire and spice it in somewhere (probably would need an EVTM), or run an aftermarket sender and gauge..
That is the single wire temp sensor in the pic. I think there is 2 wires going down, but as I can't re attach it because i don't know where its supposed to go. Thats what i am asking.
There's an oil pressure sensor sort of under the power steering bracket and usually a low oil level sender on the side of the pan.
Thats bizarre, my oil pressure gauge works.
what color is the wire?
