help me i,m stuck
duffs ranger
bought this 94 ranger with electronic 4x4 and got stuck on first night cause 4 wheel drive won,t work no lights no nothing any help let me know i was wondering if i could put manual transfer case in it and how hard
did you put it in N or P then switch it? some times you have to pump the brakes to engage it, if not that then check the fuses, and if nothing there, get a 2wd :D
The correct way to switch from hi range to low range is to come to a complete stop, with your foot on the brake and trans in neutral (clutch depressed if manual) select low range, you should hear a couple of clicks, and providing the system is working correctly, you will be in 4 low
SVT
^^ that too, i gave a more detailed(kinda) answer...but you have a 4x4.. i dont i only got to play with my dads 06 for 10 minutes in snow
