Help Me Decide.
Hahnsb2
Battle Ground WA
OK, I bought new 34x10.50 LTB swampers for my B2. I will be using my 31x10.50s for street use, they are on 15x7s, I'm going to be picking up a set of 15x8s tomorrow, I'm concerned about the 8" wheels with the swamper when running low tire pressure and I think the 7" wheel would hold a better bead, Is 1" something I should be concerned about? It would sure be cheaper/easier to just mount the swampers on the 8"s and leave my current tires and wheels together but would it be worth it to swap wheels to gain better resistance to popping a bead?
i would definatly run the 7" wheel as usually the ideal difference for truck tires rim width to tire width is 4", so for a 10.5 wide tire a 7" rim would be almost perfect for use and wont pop a bead when aired down either
