Help!! Help!!
Snapeshotz
West Virginia Weirton
Had a crash in my 2010 ranger super Cab sport 5 speed. It’s payed off don’t want a payment runs like a tank but looks like crap now.. anyone have any leads on a bed, or bedside and both passenger doors and a back bumper and OEM style flares???
Check the TRS classifieds, there are a lot of parts out there. You should post a parts wanted ad, I've placed an ad a got a response the same day, along with the parts I wanted. Welcome to the club.
thanks man thanks for the info as well man i really appreciate it. I will take your advice and post in the TRS classifieds.
Check your local Craigslist for people parting out trucks. Also can check Car-Part.com for a list of junk yards that have the parts you are looking for.
+1 on car-part.com
parts located by ZIP or postal code
Bed from 2000 - 2011 extra cab or regular cab(used same 6ft bed) will work and has same tail light wiring
There were "long bed" Rangers, 7ft, these will not fit, have a different rear frame
The 2009-2011 used 8 or 10 bed bolts and earlier just used 6, but the holes line up for either
Flares can be added to front or rear as needed
1993 to 2011 Doors are the same, regular cab or extended cab
BUT...........2006 to 2011 had different side mirrors than earlier so I would stick to those years to match your non-damaged door
There was different mounting so not just a "looks" difference
As long as the roof and floor aren't bent it should be an easy repair.
I'm not a body technician by any means but I have replaced a rear 1/4 on a del sol. Take your time and watch videos' on how its done.
area behind the tire crushed in 2".
56853
There was a 1/2" of bondo to smooth it out..
56854
new/used 1/4 attached...
56855
56856
then painted whole car...
56857
This all to show you that you can do this yourself. I only painted one vehicle before this, my Nissan. I put 3 coats of clear on it and after wet sanding and polishing the finish was like glass.
You CAN do this.
