help help help
coffey89
i have a 85 ranger 2.8 4x4 and need to know what tranny to use with my 302 swap needs to be an OD tans and need to know if i cand use my stock drive shafts
AOD Transmission, I doubt you will be able to re-use your driveshaft(s), If is a 2 piece I ESPECIALLY suspect not, and even if so, you should upgrade to a 1 piece so you don't annihilate the carrier bearing with the V-8. :headbang:
what driveshafts will i need to use on my swap?
