Help Help Help
fredsranger
edinburg texas
how can i remove those gay splash stickers on my truck w/o damaging my already damaged paint
lmfao!
I Took mine off at work with a razor blade and some vegetable oil but be careful. The sticker on the front right panel was underneath clear coat.
Vidal Sasoon!!!!
In other words a blow dryer! Plus a sticker remover spray you can get at any parts store. Here's mine removed just last night:
[/IMG]
[/IMG]
Heat them up for bout a minute after soaking them with the remover. Take your finger nail and poof! No decal!
If you want to spend some money, you can go to a auto paint store and get a decal removsal tool. It's a gum rubber wheel and an arbor that you put in a drill. It removes decals, the foam tape that's left over from trim removal and stuff like that. It works fast and doesn't harm the paint if you clean grit from the area first. The only problem is that they are about $35. I took the foam mounting tape for the full length body trim from a blazer in about 30 to 45 minutes.
Vidal Sasoon!!!!
[/IMG]
[/IMG]
hey I'm lookin into puttin some leds in my dash do u have any pics to see how urs look and what kind of leds you used. I have red bulbs in mine and they look purple
