predator
ok first im going to start with what i bought a year ago...it is a '91 explorer with a 4.0 and a 5 spd. the tranny has 12,000 miles on and the motor has 30k. the motor is out of a '96 ford explorer, the guy i bought it from told me that he just bolted on the '91 upper motor parts to get the wiring right. but after he did that the fuel pump would run when the vehicle is turned off so he told me just to lift the fuel pump fuse out and it would stop, so i did this until the vehicle started to run like crap and then it wouldn't start. so me and a good friend of mine spent 6 days with a meter and we tested every connection in the vehicle and after we ran a wire from the ground on the maf sensor it started and got back to normal.
fast forward 10 months- i painted the explorer and put in a new maf sensor and new battery cables. after i was driving it around for a couple hours i shut it down and the fuel pump started running again!!! except this time it seemed intermittant, not all the time but just every now and then, so i checked the ground and on the end that we bolted to the body i cleaned with a wire brush and reattached. i have not gotten a chance to replace the other end of the ground but i did check it but it seems ok, but im replacing it anyways..
my question-why does the fuel pump run when the vehicle is turned off? is it because the maf is not grounded? is there any thing else that could be causing this? any else ever have any problems like this??
thanks for your help!!
