sluhbmet
About a month ago my Ranger crapped out on me about 4 hours from home. The symptoms were a total loss of power and it would sometimes idle for a few seconds but die when I tried to accelerate. I suspected the fuel pump had gone bad since the truck had 205,000 miles on it and it had never been replaced. Plus I had been having to crank it longer than usual to get it started in the mornings. The repair shop confirmed it was the fuel pump and they replaced just the pump itself (Airtex-O'Reillys), the fuel strainer that fits on the end of whole assembly and the fuel filter to the tune of $430. It started and ran perfectly after that for about a week but the longer than usual cranking when trying to start in the mornings came back and now when I pull up to stop lights and push in on the clutch and come to a stop the idle sometimes drops to about 400-500 rpm and the engine starts to stumble and has died a couple of times, then it catches itself and revs back up. So I loaned the fuel pressure test kit (I don't think it had ever been used) from Autozone and I performed the fuel pressure test according to chapter 4/section 4 of the Haynes 93-97 Ranger repair manual. Fuel pressure was 30 psi with vacuum connected to regulator and 40psi with vacuum disconnected from regulator all while warmed up and idling. From what the book says, these are dead on perfect fuel pressure ranges. However, the book doesn't say anyting about what fuel pressure should be in the line after leaving it overnight, because this morning I hooked up the guage after letting it set all night and the pressure was 0 psi. And sure enough it took longer than usual to crank. Should the pressure in the line drop to zero overnight? Any advice or knowledge would be appreciated.
95 Ranger
5-speed
95 Ranger
5-speed
