Is it difficult to change? i would ratehr not pay a mechanic to do it if I could myself.
i believe that u need a 5.5mm socket to get thet module out,the modules usually do just crap out but it sounds like it runs fine till it gets to warm so if you got the money change it. besides if it is original its quite old anyways and done its job.
and just because the oil pressure switch works very well doesnt mean there might not be blockage prevent oil from getting through certain pathways.
the dealerships do offer a hot oil engine flush to clean out the engine though
fuel injectors make a noise muck like a valve ticking too
use a long bar and gently put one end to the part u suspect and the other to ur ear then ull find the noise for sure
good luck let us know how it turns out
