starquestbd22
- Feb 10, 2015
Hello all. I'll keep this quick and to the point if possible. The clutch/trans in my 2006 Ranger 2.3L is doing a few things that I consider abnormal. Was hoping someone more knowledgeable than I could point me in the right direction.
First of all, the clutch feels strong to me. Never noticed any slipping, shuddering, etc. The trans is a tad notchy but I understand that to be normal for these trucks. I haven't had the truck long and do not know it's history. I do have 3 quarts of Red Line D4 ATF ready to be swapped in as soon as I get time.
So two issues. The first and most serious IMO is that the clutch seems to engage and disengage very abruptly about half the time. Sometimes it will be very smooth but sometimes when you are either pressing or releasing the clutch during shifts it's like there is no slippage....like the engagement or disengagement is occurring immediately. When this occurs I can feel one very brief buck throughout the truck. Second, all of the gears are typically fairly smooth and easy to shift into with the exception of second gear. If I let the revs between first and second drop very low, say somewhere between 500 and 1000, it shifts into second just fine. But if I shift into second with higher revs like say 1000 to 1500, it's like I get a little resistance. Not a grind exactly. But I can feel some feedback through the shifter like it is refusing to go into gear but then it will anyway.
Thanks in advance for any suggestions!!
