help broken timing belt 97 2.3
brisranger
hi,newb here i know there is alot of posts on the timing belts,but i could not find what im looking for.its a 97 ranger 2.3 im replacing the belt and my question is for both the cam and the aux pulleys witch marks do i line up.the triangle or the diamond for the cam and aux.if i missed a thread with this info in it can somone post a link to it.also i have the chilton manual and i do not see anywhere in there on what marks to line up. thanks
The diamonds on the pulleys lign up with the diamonds on the rear cover, that should point the arrows at 12:00 o'clock. Were you able to remove the crank pulley?
