Help! Brake Problem
robs05xlt
LEBANON,PA.
Hi There:
I have a 05 ranger a/t,4x4,4dr,4.0l sohc standard 16x7 wheels & tires, with 6200 miles on the clock.Its a one owner came into Manheim auto auction from Minnesota.Yesterday morning truck started ok, while backing out & turning the s/wheel to the left I heard a groaning noise coming from the right front wheel.I then drove into town no noise.Three weeks ago( while I was applying rubber under coating to the very rusty under carriage)I found a right lower outer ball joint rubber torn.When I put my finger in that boot there should have been a little sign of grease left but there wasn't any. I had it replaced by the dealer & the alignment done.No problem, no pulling.Later on yesterday in the evening we had about 1/2" of snow. I made a couple of panic stops in 4h before getting out into traffic.I slid about 15 or 20ft. with the front brakes locked. The brake pedal was pulsating & I heard a motor noise going from a low to high speed repeatedly at the same time the pedal was pulsating.(Releasing the brake pedal stopped both problems.) This motor noise was coming from the rear of the truck. I took the truck out of 4w drive & no change, no warning lights came on in either case.Any way we went to get groceries in 4h & the brakes worked ok with light pressure & a little bit of a slide when coming to a stop at red light or another car.The streets were slick as the salt crews were not out at the time.
Thanks for any assistance provided as my 3 month warrenty is going to run out on dec16th. I have the 6yr. 100k p/train warrenty but I think that does not cover the brake system.
robs05xlt
it sounds like your just hearing and feeling the normal operation of the ABS system. as long as there are no warning lights on, it should be fine.
