- Sep 22, 2007
- Michigan
- 2.9 V6
- Manual
- My credo
- A legend to the old man, a hero to the child...
......and numbers dont mean everything.
My 400 will blast up any hill in 4th with power to spare....never once have i had to downshift up a steep hill (Except with 10000lbs+ of heavy equipment on it, then i hit third and bury the secondaries, didnt really have to but i was only going 40MPH anyways...made my blood shake, what an awesome feeling), anyways, if you wanna run a Diesel then I guess its your decsion.....but empty and empty my 400 is going to smack that 6.2L around.....and not really be any different with a load. Except ill use 3X the fuel.
My buddies 6.2L and his dads 6.5L sure wasnt anything special. The 6.5L runs good now that its almost 100% rebuilt got alot of work done to it......the 6.2L was always a turd.
The big gassers out there nowadays run as good as the Diesels, with or without a load. It just depends really on if you prefer spark plugs or glow plugs.
My two friends had 2 identical trucks, 02 Chevys 3\4tons ext cab reg box's, 3.73 in each, auto in each, one with a 8.1 and one with the 6.6 Duramax. Two mud trucks on a tri axle gooseneck and the 6.6 was running with its tounge hanging out. The 8.1 just rumbled along like nothing was there.
Diesels are fine in Semis, heavy equipment, busses, etc. But in a pickup a big block gasser just has alot of advatages. Except for fuel consumption.
later,
Dustin
later,
Dustin
