help! 1676 and 1939 code...
rednck21
Kennesaw, Ga
changed out some dash lights and noticed the abs light bulb was burnt out, too...come to find out ive got a B1676 (batt pack volt out of range)and C1939 (brake pressure switch circuit fail) code. apparently, i bought the truck with the abs light burnt out and just caught it. ive searched here and google and cant find out whats causing them. :icon_confused: any ideas or suggestions??? 02, 3.0, auto, 2wd. TIA
Here is a diagnostics to figure out the C1939 code. The other code I can only find one instance of and they are saying that it could be caused by a circuit problem with the brake pressure switch. So I would fix the C1939 code and the other one should go away. Let me know if I can help you with anything else.
