Hello to all
Mintz
New York
I have a 1996 ranger 4.0 4x4 auto super cab just installed a new transmission updated with a stall converter never giving a thought that I would have to change the baseline torque converter parameters now I am getting a code for incorrect converter speed any way to flash or fool pcm ? Thanks
Welcome!
@RonD Is the resident know-it-all (really, idk how one brain can know so much) perhaps he can be of more help.
Welcome to TRS :)
Whats the exact code number, these are a few but not all
P0740 Torque Converter Clutch Circuit Malfunction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
What torque converter model number did you put in?
All torque converters have a "stall speed" its the RPM range where they start to lock, usually around 2,000rpm for most engines, 4.0l OHV makes best torque at 2,500rpm so that would be about right for this engine
What are the symptoms while driving?
Welcome to TRS :)
Welcome to TRS :)
Welcome to TRS :)
All torque converters have a stall speed, usually 2,000rpm, can get some as high as 3,500rpm, but wouldn't matter to PCM
What is the EXACT code?
There is no "converter speed" sensor or code
And there would be no reason to flash or fool a PCM about a torque converter
There is a TSS(Input/Turbine Speed Sensor), this is an internal sensor that has a separate plug inside the pan, maybe it got unplugged?
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
Sorry to get back to you at a day later I am getting code P0741 accompanied by converter slip above expected with my code scanner ,everything in the pan is plugged in as they screwed up the wiring to the transmission coolant temperature switch that was built into the harness I had to replace that .it is supposedly a stage two transmission with a 2100 stall speed converter With the shift improver kit and extra clutches it shifts hard which is fine but occasionally the Od light Will flash and then the shifts become very very harsh And then that’s when I get the PO 741 code and again my code scanner says converter slip above expected
I had the transmission built to stage two and a stall converter because I plow with the truck in the winter and I like to make small things to do big work lol
I may be incorrect about the stall speed as well as for the place I bought it from isn’t The place I got it from ended up coming out of transmission depot which I am seeing now there’s a lot of bad reviews I am going to call them in the morning and see what stall converter they sent me
Not a torque converter issue, a TCC solenoid issue
Unplug the 16 pin connector
Use OHM meter between pin 1 and 5 should see 9 to 16 OHMs, as said in image
If out of range then solenoid is either its unplugged or bad
If in range then could be bad seal on the TCC valve inside valve body
TCC system uses a pulsed ground to gradually lock torque converter, so not abrupt on/off
P0741 means the Engine RPMs and Input shaft RPMs are not the same after TCC is applied, so torque converter is not locking up
And it could be a torque converter issue, simply a bad part, not because it has a different internal stall speed
Thank you for the info as soon as I got a minute to get her back on the lift . Again……. I will let you know what I find thank you for you patience and help
