Hello,new here.
Rangrzzz
I've got a '94 ranger. The dash lights and my running lights in the front and back went out. Everything else is ok,no fuses burnt is what got me. Help?!
Check the wiring harness under the hood that runs to the running lights...probably a loose wire...as for the dash lights...turn the headlight knob left and right (if you have a headlight knob, that is...)...
A good slap on top of the dash might help if there is a loose bulb/wire...otherwise...you may be in for some junkyard visits to tear one down...do that in the junkyard so you don't destroy your truck...if you haven't done it before, that is...:)
